I need help making a toggle button for my flywheel that I can toggle multiple speeds for the flywheel I have code for the flywheel but have to keep it pressed for to keep the flywheel going
code for non toggle:
if(Controller1.ButtonUp.pressing()) {
Flywheel.spin(directionType::fwd, 200, velocityUnits::rpm);
else {
Flywheel.stop(brakeType::coast);
add a void function above the main task to set the flywheel speed, use variable that holds the desired speed, and change that variable value by button presses:
void setFlywheelRPM(int _rpm){
if (_rpm == 0){
Flywheel.stop(); // stop flywheel if rpm is 0
else {
Flywheel.spin(directionType::fwd, _rpm, velocityUnits::rpm);
// ... then in the user control section...
void usercontrol( void ) {
int FlywheelRPM = 0; // declare a variable to hold the desired flywheel rpm
Flywheel.setStopping(brakeType::coast); // always coast flywheel motor
while (1){
FlywheelRPM = 600; // high rpm on up
if(Controller1.ButtonLeft.pressing()) {
FlywheelRPM = 400; // low rpm on left
if(Controller1.ButtonDown.pressing()) {
FlywheelRPM = 0; // stop flywheel on down
setFlywheelRPM(FlywheelRPM); // send the desired rpm to setFlywheelRPM function
vex::task::sleep(20); //Sleep the task for a short amount of time to prevent wasted resources.
There are a few other ways of doing it, but the main principle is in your code it is testing for every moment the flywheel button is not pressed, the else immediately shuts off your flywheel because of the brake command. If you need some more help or would like your new system reviewed feel free to PM me, I’d be happy to assist.
