Vex Cad Library
Can anyone send me an updated Vex CAD Library full of the Vex parts? I need all the new parts and old parts in one place. I need it for AutoCAD and Solidworks
I will have one uploaded and available in the next month or two. Sorry I can’t have it ready sooner, but I’m revamping mine and with life and such it’s gonna take a bit of time.
Can I piggy-back on this thread?..
Does anyone have a Inventor 2010 version of the VEX CAD library they can share?
Just finished updating my library. It contain all the parts as of today, with iMates and Construction surfaces. Feel free to use it!
VEX Part Library 2016 Download
Library Contains:
Structure:
  • C-Channel 1x5x1 (All lengths)
  • C-Channel 1x3x1 (All lengths)
  • C-Channel 1x2x1 (All lengths)
  • 2000+ iMates x_x
  • Standoffs (All sizes)
  • 45 Degree Angle Gusset
  • 90 Degree Angle Gusset Inner
  • 90 Degree Angle Gusset Outer
  • Angle 2x2 (All lengths)
  • Angle 3x3 (All lengths)
  • Angle Gusset
  • Angle Corner Gusset
  • Angle Coupler Gusset
  • C-Channel Coupler Gusset
  • Plate (All lengths)
  • Bar (All lengths)
  • Nylock
  • Keps Nut
  • 8-32 Hex Head Screws (All sizes)
  • 6-32 Hex Head Screws (0.25" and 0.5")
  • 8-32 Star Head Screws (All sizes)
  • Base Plate
  • Pop Rivets
  • Bevel Gearbox Bracket
  • Hinge
  • Hex Drive Couplers (0.25" and 0.5")
  • Star Drive Couplers (0.25" and 0.5")
  • Nut Bar (20 Hole)
  • Pivot Gusset
  • Plus Gusset
  • Rubber Link
  • Rail (All lengths)
  • Rack Gearbox Bracket
  • Thumbscrew
  • Shoulder Screw
  • Slotted Angle 30 Hole (Discontinued)
  • Swerve Bracket
  • Winch Bracket
  • Worm Gearbox Bracket
  • Linear Slider Tracks (All lengths)
Motion:
  • 2.5" Traction Wheel
  • 2.75" Omni-Directional Wheel
  • 3.25" Traction Wheel
  • 4" Traction Wheel
  • 4" High Traction Wheel
  • 5" Traction Wheel
  • 4" Omni-Directional Wheel
  • Mecanum Wheel
  • 3.25" Omni-Directional Wheel
  • 6" Wheel Leg
  • 393 Motor
  • 393 Motor with Integrated Encoder Module (IEM)
  • 269 Motor
  • 269 Motor with Integrated Encoder Module (IEM)
  • 3 Wire Servo Motor
  • 12 Tooth Gear
  • 12 Tooth Pinion Gear
  • 36 Tooth Gear
  • 60 Tooth Gear
  • 84 Tooth Gear
  • High Strength 12 Tooth Gear
  • High Strength 36 Tooth Gear
  • High Strength 60 Tooth Gear
  • High Strength 84 Tooth Gear
  • 16 Tooth Bevel Gear
  • 24 Tooth Bevel Gear
  • 32 Tooth Bevel
  • 60 Tooth Turntable
  • 66 Tooth Turntable
  • 19 Tooth Rack Gear (v1, not the updated v2 rack gear)
  • Worm Gear
  • Worm Wheel
  • Differential Frame
  • 15 Tooth Sprocket
  • 24 Tooth Sprocket
  • 40 Tooth Sprocket
  • High Strength 6 Tooth Sprocket
  • High Strength 12 Tooth Sprocket
  • High Strength 18 Tooth Sprocket
  • High Strength 24 Tooth Sprocket
  • High Strength 30 Tooth Sprocket
  • Chain Link
  • High Strength Chain Link
  • Tank Tread Drive Wheel
  • Tank Tread Link
  • Tank Tread Traction Link
  • Conveyor Belt Link
  • Short Conveyor Belt Insert
  • Medium Conveyor Belt Insert
  • Tall Conveyor Belt Insert
  • Tank Drive Idler Double Wheel
  • Tank Drive Idler Single Wheel
  • High Strength Chain Attachment
  • Intake Roller
  • Winch Drum
  • Rachet Gear
  • Winch Pawl
  • Hand Crank
  • Pulley
  • Claw Kit (Assembled and Working)
  • Lead Screw Mounting Segment
  • Lead Screw Nut
  • Linear Slider Inner Truck
  • Linear Slider Outer Truck
  • Cam
  • Cam Follower
  • Cam Follower Mounting Bracket
  • Clutch
  • Free Spinning Insert
  • High Strength Square Insert
  • 0.125" Shaft (All lengths)
  • High Strength 0.25" Shaft (All lengths)
  • Pillow Bearing
  • Bearing Flat
  • High Strength Bearing Flat
  • Lock Bar
  • Drive Shaft Lock Bar
  • Clamping Shaft Collar
  • Nylon Spacers (All sizes)
  • Black, Plastic Spacers (8mm and 4.6mm)
  • Steel Washer
  • Teflon Washer
  • Rubber Shaft Collar
  • Shaft Collar
  • High Strength Clamping Shaft Collar
  • High Strength Spacers (All sizes)
  • Universal Joint (Not 100% functional)
  • Pneumatic “T” Fitting
  • Pneumatic Single Action Solenoid
  • Pneumatic Double Action Solenoid
  • Pneumatic Single Action Piston
  • Pneumatic Double Action Piston
  • Pneumatic Finger Valve
  • Pneumatic Reservoir
  • Pneumatic 4mm Tube Solenoid Fitting
  • Pneumatic 4mm Tube Reservoir Valve Fitting
  • Pneumatic 4mm Tube Piston Valve Fitting
  • Pneumatic 4mm Tube Out Flow Elbow
Sensors:
  • 269 Integrated Encoder Module (IEM)
  • 393 Integrated Encoder Module (IEM)
  • Analog Accelerometer
  • Bumper Switch
  • LCD Display
  • Light Sensor
  • Limit Switch
  • Line Tracker
  • Optical Shaft Encoder
  • Potentiometer
  • Speaker Module
  • Yaw Rate Gyro Sensor
Power:
  • 7.2V 2000mAh Battery
  • 7.2V 3000mAh Battery
  • Battery Clip
  • Battery Extension Cable
  • Power Expander
  • Backup Battery Holder
Logic:
  • Cortex
Oh, wow, that’s a lot of parts. Thanks a bunch!
Thank You. Really appreciate it.
Thank you so much!
Very nice. Thank you. I’ve upgraded to Inventor 2017 so now we can use these.
Thanks! That saves me a lot of work :slight_smile:
Thank you very much!
we appreciate the work oyu’ve done. But we are interested in learning how to create vex libraries with imates. Can someone share directions on how to do this?
thanks.
Are you wanting to know how to add iMates onto parts that don’t already have them?
Yes.
