I wanted to see statistically what people plan to do for this season. I want to know If I’m alone in how I feel and how I approach this year’s game.
How do you rate this year’s game (10 The Highest)
When will you start construction for your robot
End of April
May
June
July
August
When Quarantine is over because your robot kit is at school.
What type of base will you build?
H-Drive
Tank Drive
Mech. Wheel Drive
X-Drive
Kiwi
Other
What Lift will be used on your robot?
No Lift
Dr4Bar
Dr6Bar
2Bar
Cascade (Bruh)
Forklift Chain Lift
Or
Intake Design?
Pretty Much Tower Takeover Intakes
Tredmill to drop cube into goals
Other
How Easy Does Skills Look? (10 SUPER EZZZ)
Will You Use Ball Indexing (Sort Colors)
Where’s the four bar option?
The Dr4bar, Double Reverse 4 Bar
There’s a difference between an DR4B and just a 4 bar…
I know, but regular four bar isn’t an option
Ok lemme add that, sorry about that
Apparently, its been 5 minutes, too late
imagine building a dr4b to reach an 18" goal
But that L I N E A R M O T I O N
RNA
April 26, 2020, 2:34am
10
they could work though. make them small enough could work well. and of course the VERTICAL MOTION
build a scissor lift because someone has made a good one of those ever
if you’re making anything bigger than a 4 bar you’re doing something wrong.
RNA
April 26, 2020, 2:39am
14
im always wrong so here I go again
Welcome to early season vex in a nutshell
RNA
April 26, 2020, 2:41am
16
dr4bs might work out. we need to test in my opinion
Hm. they might be semi-viable for moving your tray up. My 1st initial thought was a dr4b traybot (but a little more optimized), but now I’m thinking of ways to not use a dr4b, or have an elevator system. if you had a wide area of intaking, then had an elevator, you could, theoretically, use it. It’s not the brightest design, but hey, it’s one ig.
GIML
April 26, 2020, 12:03pm
18
What the heck is ball indexing?
Ball indexing is where the robot sorts the colors .
I think I’m going to close this soon, and do another one at the end of this season to see if opinions or designs have greatly changed.
