Vex Clawbot Gyroscope?
Hey guys!
Recently I’ve seen the Vex Armbot on Youtube and 17 seconds into the video the driver tilts his controller and the Robot mirrors him! Now is that based off of a gyroscope or is that just an illusion? If it’s real I would really love to learn the programming for it and get the parts necessary for the robot. I think it would have some potential in Toss Up!
Thanks
-Christian
http://www.vexrobotics.com/276-2192.html
The VEX joystick has a built in 2-axis accelerometer.
In RobotC, the values can be read using
vexRT[AccelX]
and
vexRT[AccelY]
That was Josh’s from 1103 summer intern project. It used the gyroscope built in the controller to send a value out to the motor.
EDIT: Not sure if it was a gyroscope or accelerometer.
Would you guys happen to know any websites or videos that show how to program for this?
it is the accelerometer …
here is a robotc sample program, i used it when i first started vex a couple of years ago …
pretty easy 2 adapt … hope this helps
#pragma config(Motor, port2, rightMotor, tmotorNormal, openLoop, reversed)
#pragma config(Motor, port3, leftMotor, tmotorNormal, openLoop)
|* - VEXnet Accelerometer Control - |
ROBOTC on VEX 2.0 Cortex |
This program uses the built-in Accelerometer Sensor of the VEX 2.0 CORTEX Controller to control |
the robot. |
ROBOT CONFIGURATION |
NOTES: |
1) Tilting the controller DOWN, or FORWARD, gives a NEGATIVE reading on Y. |
2) Tilting the controller UP, or BACK, gives a POSITIVE reading on Y. |
3) Tilting the controller LEFT gives a NEGATIVE reading on X. |
4) Holding the controller RIGHT gives a POSITIVE reading on X. |
5) ‘abs(z)’ is the ABSOLUTE VALUE of ‘z’. |
MOTORS & SENSORS: |
* [Name] [Type] [Description] |
Motor - Port 2 rightMotor VEX Motor Right motor |
Motor - Port 3 leftMotor VEX Motor Left motor |
//+++++++++++++++++++++++++++++++++++++++++++++| MAIN |+++++++++++++++++++++++++++++++++++++++++++++++
task main()
int accel_x = 0; // Will hold the controller-accelerometer X reading.
int accel_y = 0; // Will hold the controller-accelerometer Y reading.
int prev_x = 0; // Will hold the previous accelerometer X reading (for comparison).
int prev_y = 0; // Will hold the previous accelerometer Y reading (for comparison).
int threshold = 10; /* Used to cancel ‘noise’ of low values as well as /
ignore spikes in accelerometer sensor readings. */
while(1 == 1)
prev_x = accel_x; // update previous x reading to ‘accel_x’
prev_y = accel_y; // update previous y reading to ‘accel_y’
accel_x = vexRT[AccelX]; // update ‘accel_x’ to new current reading
accel_y = vexRT[AccelY]; // update ‘accel_y’ to new current reading
// is abs(current - prev) < threshold?
if( (abs(accel_x - prev_x) < threshold) || (abs(accel_y - prev_y) > threshold) )
// YES.
  // Are either of them over the 'noise' threshold?
  if( (abs(accel_x) > threshold) || (abs(accel_y) > threshold) )
  // YES.
    if(accel_y > 0) // going backwards?
      motor[leftMotor]  = ((-1 * accel_y) - accel_x)/2;
      motor[rightMotor] = ((-1 * accel_y) + accel_x)/2;
    else  // going forward, or point turn:
      motor[leftMotor]  = ((-1 * accel_y) + accel_x)/2;
      motor[rightMotor] = ((-1 * accel_y) - accel_x)/2;
  // NO - give no power to motors, joystick is in center position (or near enough to it)
  else
    motor[leftMotor]  = 0;
    motor[rightMotor] = 0;
// NO - make no changes.
wait1Msec(20);      // the VEXnet controller updates every 15ms or so
Yes this helps a lot :slight_smile: thanks everyone!
Could you edit your post and add code tags? It is much more readable like this:
|*                                 - VEXnet Accelerometer Control -                                   *|
|*                                     ROBOTC on VEX 2.0 Cortex                                       *|
|*  This program uses the built-in Accelerometer Sensor of the VEX 2.0 CORTEX Controller to control   *|
|*  the robot.        *|
|*                                        ROBOT CONFIGURATION                                         *|
|*    NOTES:        *|
|*    1)  Tilting the controller DOWN, or FORWARD, gives a NEGATIVE reading on Y.                     *|
|*    2)  Tilting the controller UP, or BACK, gives a POSITIVE reading on Y.                          *|
|*    3)  Tilting the controller LEFT gives a NEGATIVE reading on X.                                  *|
|*    4)  Holding the controller RIGHT gives a POSITIVE reading on X.                                 *|
|*    5)  'abs(z)' is the ABSOLUTE VALUE of 'z'.                                                      *|
|*    MOTORS & SENSORS:        *|
|*    *              [Name]              [Type]              [Description]                   *|
|*    Motor - Port 2          rightMotor           VEX Motor           Right motor                    *|
|*    Motor - Port 3          leftMotor            VEX Motor           Left motor                     *|
task main()
  int threshold = 10;     /* Used to cancel 'noise' of low values as well as */
                          /* ignore spikes in accelerometer sensor readings. */
  while(1 == 1)
    prev_x = accel_x;           // update previous x reading to 'accel_x'
    prev_y = accel_y;           // update previous y reading to 'accel_y'
    accel_x = vexRT[AccelX];    // update 'accel_x' to new current reading
    accel_y = vexRT[AccelY];    // update 'accel_y' to new current reading
    // YES.
      // YES.
      else
for some reason it won’t let me edit it so … here it is
|*  the robot.        *|
|*    NOTES:        *|
task main()
  while(1 == 1)
    // YES.
      // YES.
      else
now … basically plug in motors to port 2 & 3 … and as you move the joystick around the values control the output to the motors …*
