Vex Code error (V5)
I have sucessful codes with two controllers, however, when I moved it to one controller the VexCodeInit() lines started to cause errors. I have tried to reload the program, but that has not worked. Can anyone potentially tell me what is wrong with the code?
#include "vex.h"
using namespace vex;
competition Competition;
void pre_auton(void) {
  vexcodeInit();
// START AUTONOMOUS
void autonomous(void) {
 // Display on screen
 Brain.Screen.print("Autonomous has started");
 // Move forward
 FrontLeftDriveMotor.rotateFor(0.9, rotationUnits::rev, false);
 FrontRightDriveMotor.rotateFor(0.9, rotationUnits::rev, false);
 BackLeftDriveMotor.rotateFor(0.9, rotationUnits::rev, false);
 BackRightDriveMotor.rotateFor(0.9, rotationUnits::rev);
// START DRIVER CONTROL
void usercontrol(void) {
#include "vex.h"
 vexcodeInit();
 // Display that the program has started on the screen
 Brain.Screen.print("Driver control started");
 // Create and infinite loop so that the program can pull remote control values every iteration
 while(1){
    // Set motor speeds
    int clawSpeedPCT = 40;
    int driveSpeedPCT = 75;
    int armSpeedPCT = 50;
    // DRIVE CONTROL
    // If button left is pressed
    if(Controller1.ButtonLeft.pressing()) {
      // Move robot left
      FrontLeftDriveMotor.spin(vex::directionType::rev, driveSpeedPCT, vex::velocityUnits::pct);
      BackLeftDriveMotor.spin(vex::directionType::fwd, driveSpeedPCT, vex::velocityUnits::pct);
      FrontRightDriveMotor.spin(vex::directionType::fwd, driveSpeedPCT, vex::velocityUnits::pct);
      BackRightDriveMotor.spin(vex::directionType::rev, driveSpeedPCT, vex::velocityUnits::pct);
    // Else if button right is pressed
    else if(Controller1.ButtonRight.pressing()) {
      // Move robot right
      FrontLeftDriveMotor.spin(vex::directionType::fwd, driveSpeedPCT, vex::velocityUnits::pct);
      BackLeftDriveMotor.spin(vex::directionType::rev, driveSpeedPCT, vex::velocityUnits::pct);
      FrontRightDriveMotor.spin(vex::directionType::rev, driveSpeedPCT, vex::velocityUnits::pct);
      BackRightDriveMotor.spin(vex::directionType::fwd, driveSpeedPCT, vex::velocityUnits::pct);
    // Else if button up is pressed
    else if(Controller1.ButtonUp.pressing()) {
      // Move robot forward
    // Else if button down is pressed
    else if(Controller1.ButtonDown.pressing()) {
      // Move robot backward
    // Else if neither button left or button right is pressed
   else {
     // Set the left and right motor to spin forward using the controller's axis positions as the velocity units
      FrontLeftDriveMotor.spin(vex::directionType::fwd, Controller1.Axis3.position()*0.75, vex::velocityUnits::pct);
      BackLeftDriveMotor.spin(vex::directionType::fwd, Controller1.Axis3.position()*0.75, vex::velocityUnits::pct);
      FrontRightDriveMotor.spin(vex::directionType::fwd, Controller1.Axis2.position()*0.75, vex::velocityUnits::pct);
      BackRightDriveMotor.spin(vex::directionType::fwd, Controller1.Axis2.position()*0.75, vex::velocityUnits::pct);
    // ARM CONTROL
    // If button L1 is pressed
    if(Controller1.ButtonL1.pressing()) {
      // Spin the arm motors forward
      ArmMotorLeft.spin(vex::directionType::fwd, armSpeedPCT, vex::velocityUnits::pct);
      ArmMotorRight.spin(vex::directionType::rev, armSpeedPCT, vex::velocityUnits::pct);
    // Else if button L2 is pressed
    else if(Controller1.ButtonL2.pressing()) {
      // Spin the arm motors backward
      ArmMotorLeft.spin(vex::directionType::rev, armSpeedPCT, vex::velocityUnits::pct);
      ArmMotorRight.spin(vex::directionType::fwd, armSpeedPCT, vex::velocityUnits::pct);
    // Else if neither button L1 or button L2 is pressed
    else {
      // Stop the arm motors
      ArmMotorLeft.stop(vex::brakeType::brake);
      ArmMotorRight.stop(vex::brakeType::brake);
    // CLAW CONTROL
    // If button R1 is pressed
    if(Controller1.ButtonR1.pressing()) {
      // Spin the claw motors forward
      ClawMotor1.spin(vex::directionType::fwd, clawSpeedPCT, vex::velocityUnits::pct);
      ClawMotor2.spin(vex::directionType::rev, clawSpeedPCT, vex::velocityUnits::pct);
    // Else if button R2 is pressed
    else if(Controller1.ButtonR2.pressing()) {
      // Spin the claw motors backward
      ClawMotor1.spin(vex::directionType::rev, clawSpeedPCT, vex::velocityUnits::pct);
      ClawMotor2.spin(vex::directionType::fwd, clawSpeedPCT, vex::velocityUnits::pct);
    // Else if neither button R1 or button R2 is pressed
    else {
      // Stop the claw motors
      ClawMotor1.stop(vex::brakeType::brake);
      ClawMotor2.stop(vex::brakeType::brake);
    // This is the main execution loop for the user control program.
    // Each time through the loop your program should update motor + servo
    // values based on feedback from the joysticks.
    // Insert user code here. This is where you use the joystick values to
    // update your motors, etc.
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
Looks like you copy-pasted a previous project into the usercontrol segment. The include, namespace, and vexcodeInit() lines are already at the top of the file, so they aren’t needed again inside your usercontrol function.
In other words, delete these lines:
void usercontrol(void) { //keep the loop
#include "vex.h" //DELETE ME
using namespace vex; //DELETE ME
 vexcodeInit(); //DELETE ME
I used the fixes you said and it caused a lot more errors because now it is saying all the variables are not defined
hm, do you think you could upload your entire project? I think you probably have an error between files. It builds fine for me.
Make sure you deleted the include in the usercontrol and not the one at the top of the file.
