Vex Code Problem
I have a problem with my code when I plug into a match controller.
My robot shoots string when I turn a gear with a rubber band attacthed to it and when the motor turns the rubber bands line up with the axel where the other end is attachted to and the string fires.
On my program I put When start set motor 8(the string launching motor) stopping to hold - so that the motor stops the gear from spinning when I attach the rubber bands.
My problem is when I plug in to a match controller my program pauses and the motor stops holding the gear and the string miss fires.
Is there any way I can get around this through programming?
No, all motors are disabled and set to coast before a match starts.
