Vex coding issue
Hello I was programming for my team and I was having a compiler issue with coding studio and I was told I should start using vexCode. I imported my program from vcs to vc. I hit build and It says building for a while then says building took longer than 60 seconds hit abort. So I initially thought it was the fact that I imported it so I tried a different program that was made in vc but it said the same thing. I really need something to work please help! I really need help. I also posted this on the vexcode support forum topic.
No need to post two topics with the same issue, I will delete the other one.
Copy and paste the contents of the output panel here so we can get some sense of what happens when you try and build your project. Are you saying that even a new empty project will not build ? Are you on Mac or PC ?
