Vex::competition Competition; problems
it says
16:24:25 – info – changed directory: C:/Users/401763/AppData/Local/VEX Coding Studio/VEX Coding Studio/sdk/user/
16:24:25 – info – C:/Users/401763/AppData/Local/VEX Coding Studio/VEX Coding Studio/sdk/user/
16:24:25 – info – file removed: C:/Users/401763/AppData/Local/VEX Coding Studio/VEX Coding Studio/sdk/user/cxx.o
16:24:25 – info – clang version 5.0.1 (tags/RELEASE_501/final)
Target: thumbv7-none–eabi
Thread model: posix
InstalledDir: C:\Program Files (x86)\VEX Robotics\VEX Coding Studio\node_modules@modkit\modkit-compiler-binaries-windows\clang\bin
“C:\Program Files (x86)\VEX Robotics\VEX Coding Studio\node_modules\@modkit\modkit-compiler-binaries-windows\clang\bin\clang.exe” -cc1 -triple armv7-none–eabi -emit-obj -disable-free -disable-llvm-verifier -discard-value-names -main-file-name cxx_entry.cpp -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -no-integrated-as -mconstructor-aliases -nostdsysteminc -target-cpu generic -target-feature +soft-float-abi -target-feature -fp-only-sp -target-feature -d16 -target-feature +vfp3 -target-feature -fp16 -target-feature -vfp4 -target-feature -fp-armv8 -target-feature +neon -target-feature -crypto -target-feature +strict-align -target-abi aapcs -mfloat-abi soft -v -dwarf-column-info -debugger-tuning=gdb -ffunction-sections -fdata-sections -coverage-notes-file “C:\Users\401763\AppData\Local\VEX Coding Studio\VEX Coding Studio\sdk\user\cxx.gcno” -nostdinc++ -resource-dir “C:\Program Files (x86)\VEX Robotics\VEX Coding Studio\node_modules\@modkit\modkit-compiler-binaries-windows\clang\lib\clang\5.0.1” -D _LIBCPP_HAS_NO_EXCEPTIONS -D _LIBCPP_HAS_NO_THREADS -D VexV5 -I . -I …/clang/7.0.0/include -I …/vexv5/include -I …/vexv5/gcc/include -I …/vexv5/gcc/include/c++/4.9.3 -I …/vexv5/gcc/include/c++/4.9.3/arm-none-eabi/armv7-ar/thumb -I …/modkit -internal-isystem “C:\Program Files (x86)\VEX Robotics\VEX Coding Studio\node_modules\@modkit\modkit-compiler-binaries-windows\clang\lib\clang\5.0.1\include” -internal-isystem include -Os -Wno-unknown-attributes -Werror=return-type -Wall -std=gnu++11 -fdeprecated-macro -fdebug-compilation-dir “C:\Users\401763\AppData\Local\VEX Coding Studio\VEX Coding Studio\sdk\user” -ferror-limit 19 -fmessage-length 0 -fallow-half-arguments-and-returns -fno-rtti -fshort-enums -fno-signed-char -fno-threadsafe-statics -fobjc-runtime=gcc -fdiagnostics-show-option -vectorize-loops -vectorize-slp -o cxx.o -x c++ cxx_entry.cpp
clang -cc1 version 5.0.1 based upon LLVM 5.0.1 default target i686-pc-windows-msvc
ignoring nonexistent directory “C:\Program Files (x86)\VEX Robotics\VEX Coding Studio\node_modules@modkit\modkit-compiler-binaries-windows\clang\lib\clang\5.0.1\include”
ignoring nonexistent directory “include”
#include “…” search starts here:
#include <…> search starts here:
…/vexv5/include
…/vexv5/gcc/include
…/modkit
End of search list.
16:24:25 – info – make process failed with return code: 1
pls help
what is the issue :face_with_monocle:
I just updated didn’t realize you cant have 2 images
is your issue like you cant save or download to robot because that’s what it seems it doesn’t look like a problem with the code itself try saving it to another/new folder and see if that helps
it says the same thing when compiling but I can save the program
