Hello i get the error “In included file expected name space name”
In that file type using namespace vex
Here is my code:
ROBOSHEEN-config.h:
using namespace vex;
extern vex::brain Brain;
* Used to initialize code/tasks/devices added using tools in VEXcode Text.
* This should be called at the start of your int main function.
void vexcodeInit(void);
ROBOSHEEN.h
#include "ROBOSHEEN-config.h"
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "v5.h"
#include "v5_vcs.h"
#define waitUntil(condition) \
do { \
wait(5, msec); \
} while (!(condition))
#define repeat(iterations) \
for (int iterator = 0; iterator < iterations; iterator++)
double sgn(double number);
void close_claw();
void setLeftPower(int power);
void setRightPower(int power);
void setDrivePower(int left, int right);
void driveStraight(int distance, int power);
void printLineTrackerValue();
// if pass 50, means 50% power
void driveForwardByVelocity(double velocity, int power);
bool isZeroValues();
void see_light_stop(double velocityl, double velocityr);
void hit_wall(double velocity_left, double velocity_right, int sleep_time);
void open_claw();
void see_dark_stop(double velocityl, double velocityr);
void back_see_light_stop(double velocityl, double velocityr);
void back_see_dark_stop(double velocityl, double velocityr);
//trun right: autoTurn(100), slower Turn(100, 30)
void turn_right(int distance, int power) ;
main.cpp
#include "ROBOSHEEN.h"
int main() {
vexcodeInit();
setDrivePower(50, 50);
driveStraight(720, 50);
//setHDrivePower(50);
//HDrive(360, 50);
driveStraight(-720, 50);
//HDrive(-360, 50);
ROBOSHEEN-config.cpp:
#include <iostream>
#include <vex_triport.h>
#include <cmath>
// A global instance of brain used for printing to the V5 brain screen
brain brain1;
vex::motor ClawMotor = vex::motor(vex::PORT3);
vex::motor LtMotorF = vex::motor(vex::PORT7);
vex::motor RtMotorF = vex::motor(vex::PORT16);
vex::motor LtMotorB = vex::motor(vex::PORT2);
vex::motor RtMotorB = vex::motor(vex::PORT14);
vex::motor HMotor = vex::motor (vex::PORT4);
vex::motor Motor1 = vex::motor(vex::PORT6, true);
vex::motor Motor2 = vex::motor(vex::PORT19, true);
vex::controller Controller1 = vex::controller();
motor_group LeftMotor (LtMotorB,LtMotorF);
motor_group RightMotor(RtMotorB,RtMotorF);
line LineTrackerL = line(Brain.ThreeWirePort.A);
line LineTrackerM = line(Brain.ThreeWirePort.B);
line LineTrackerR = line(Brain.ThreeWirePort.C);
void close_claw(){
ClawMotor.spin(directionType::fwd, 100, velocityUnits::pct);
task::sleep(750);
while (ClawMotor.velocity(pct) > 0) {
ClawMotor.stop(brakeType::hold);
void setLeftPower(int power) {
if (power == 0)
LeftMotor.stop(vex::brakeType::brake);
else {
LeftMotor.spin(vex::directionType::fwd, power, vex::velocityUnits::pct);
void setRightPower(int power) {
if (power == 0)
RightMotor.stop(vex::brakeType::brake);
else {
RightMotor.spin(vex::directionType::rev, power, vex::velocityUnits::pct);
void setDrivePower(int left, int right) {
setLeftPower(left);
setRightPower(right);
void driveStraight(int distance, int power = 100) {
int direction = sgn(distance);
// Clear encoder
LtMotorB.resetRotation();
while (std::abs(LtMotorB.rotation(vex::rotationUnits::deg)) < std::abs(distance)) {
setDrivePower(power * direction, power * direction);
setDrivePower(0, 0);
Brain.Screen.clearScreen();
Brain.Screen.setFont(monoS);
Brain.Screen.print(Brain.Timer.value());
while(true)
task::sleep(3000);
Brain.Screen.newLine();
Brain.Screen.print(LineTrackerL.value(analogUnits::range12bit));
Brain.Screen.print(LineTrackerM.value(analogUnits::range12bit));
Brain.Screen.print(LineTrackerR.value(analogUnits::range12bit));
void driveForwardByVelocity(double velocity) {
LeftMotor.spin(directionType::fwd, velocity, vex::velocityUnits::pct);
RightMotor.spin(directionType::rev, velocity, vex::velocityUnits::pct);
bool isZeroValues()
if (LineTrackerL.value(analogUnits::range12bit) == 0 &&
LineTrackerM.value(analogUnits::range12bit) == 0 &&
LineTrackerR.value(analogUnits::range12bit) == 0 ) {
return true;
return false;
void see_light_stop(double velocityl, double velocityr) {
while (true) {
//driveForwardByVelocity(40);
LeftMotor.spin(directionType::fwd, velocityl, velocityUnits::pct);
RightMotor.spin(directionType::rev, velocityr, velocityUnits::pct);
if (!isZeroValues() &&
(LineTrackerL.value(analogUnits::range12bit) < 1500 ||
LineTrackerM.value(analogUnits::range12bit) < 1500 ||
LineTrackerR.value(analogUnits::range12bit) < 1500) ){
break;
LeftMotor.stop(brakeType::hold);
RightMotor.stop(brakeType::hold);
void hit_wall(double velocity_left, double velocity_right, int sleep_time){
LeftMotor.spin(directionType::rev, velocity_left, velocityUnits::pct);
RightMotor.spin(directionType::fwd, velocity_right, velocityUnits::pct);
task::sleep(sleep_time);
while (LeftMotor.velocity(pct) > 0 && RightMotor.velocity(pct)> 0) {
void open_claw(){
ClawMotor.spin(directionType::rev, 100, velocityUnits::pct);
task::sleep(500);
void see_dark_stop(double velocityl, double velocityr) {
while (true) {
(LineTrackerL.value(analogUnits::range12bit) > 1500 ||
LineTrackerM.value(analogUnits::range12bit) > 1500 ||
LineTrackerR.value(analogUnits::range12bit) > 1500) ){
break;
void back_see_light_stop(double velocityl, double velocityr) {
while (true) {
//drive Back
LeftMotor.spin(directionType::rev, velocityl, velocityUnits::pct);
RightMotor.spin(directionType::fwd, velocityr, velocityUnits::pct);
break;
void back_see_dark_stop(double velocityl, double velocityr) {
while (true) {
//drive Back
break;
void turn_right(int distance, int power) {
// Clear encoder
LeftMotor.resetRotation();
RightMotor.resetRotation();
while (std::abs(LeftMotor.rotation(vex::rotationUnits::deg)) <std::abs(distance)) {
setDrivePower(power * direction, -power * direction);
//trun left: autoTurn(100), slower Turn(100, 30)
void turn_left(int distance, int power) {
// Clear encoder
setDrivePower(-power * direction, power * direction);
void vexcodeInit(void) {
// Nothing to initialize
I did and it still doesn’t work
Thanks for including your complete program! That makes it much easier to debug these sorts of things.
ROBOSHEEN-config.h
threw an error on
because that file doesn’t know about the vex
namespace in the first place, since the files that define that namespace aren’t included.
I added the following two Iines to the top of ROBOSHEEN-config.h
#include "v5.h"
#include "v5_vcs.h"
and that solved the “expected namespace name” error - although the project still failed to compile due to an error in the driveStraight
function.
