I am looking for the technical spec/data sheet of the vex controller. Where can I find it? I want to communicate with it using Lab View. Has anyone tried it?
**The Spec/Data is located on the Started Kit web page, http://www.vexlabs.com/vex-robotics-design-system.shtml, under Vex Micro Controller Specifications.
We have a zip file that should contain everything you need to get a Vex “LabView Dashboard” up and running. You must already have LabView and a Vex Programming Module. Some instructions are included in pdf files. The instructions were written for a different application so not everything will apply to your situation. This was developed as a donation and can be used freely but can not be used for profit. E-mail us if you would like the zip file: [email protected]. These file are based on using MPLAB.**
