Vex explorer motor full speed?
I am wondering if there is a simple mod using minimal components that could allow me to drive the vex explorer motor at full speed only.
This way i won’t need a speed controller as i use the motors at full speed much more often.
This is so that i can run the motor from the vex microcontroller.
You can rig a simple circuit where a digital out controls a transistor that powers the motor. Note that this will only give you 1-directional spinning; you can’t reverse this way. I did this a while back using TIP110 transistors to run some relays and it worked like a charm. I’ll post a schematic after I get home this evening.
If you need 2-directional control (forward and reverse), you’d need a more complicated circuit called an H-bridge and that would take up two digital ports.
Cheers,
  • Dean
like this.
or this.
or this.
Here is a more graphical representation, for folks who are not confident with schematics. I’ve used this circuit to run relays and incandescent lamps many times in the past. Radio Shack part numbers are included for your convenience.
http://homepage.mac.com/dean.reece/Vex/TIP110.png
Cheers,
  • Dean
Thanks that was really helpful.
Now i just need to go and order some parts off Digikey.
I need some connectors, transistor, and the diode.
Well this is cool but how much current can you get out of this?
I may already have all these parts!
I have some large IGBT’s i ordered a while ago for an inductor charging unit for capacitors but i never used them. I also have 10,000 diodes and 10,000 resistors.
The TIP110 is good for 2A, and the TIP120 is good for 5A.
Both are rated for up to 60VDC.
Just so you know, the diode is there to protect the transistor from
back-emf/counter-emf. The circuit will work without it, but there is some risk of damage to the transistor.
Cheers,
  • Dean
And what did you use to generate that diagram??? That is so very neat and clean.
Thanks! I used a Macintosh program called OmniGraffle Pro. It is mainly a charting and diagraming tool, but I’ve had a lot of luck using it for drawings like this.
Cheers,
  • Dean
I was wondering what you used to draw that, it looks nice and tidy and you can see all of the components.
can you controlle a led and turn it on or off in a program with this setup?
Yes, though you will need a current limiting resistor of around 180Ω or 220Ω wired in series for a standard 20mA LED. For high-power LEDs, you would probably need a different value. Also, you can remove the 1N400x rectifier from the schematic above, since it is only needed when driving inductive loads like motors or relays.
If you are just trying to get an LED to glow enough that you can see it (like a status indicator) then you can hook it directly to an I/O port: cathode to white, anode to red. You really only need the transistor driver if you are trying to make an LED glow brightly (like a LED floodlight).
Cheers,
  • Dean
im actualy trying to make the mouth of a robot light up so the flood light is what i need
and do you have any idea how many volts it puts out?
The circuit at the top of this thread will output around 4.6V at up to 1A.
Cheers,
  • Dean
got to try that thanks m8
