VEX Hinge CAD File
It appears that there is no CAD file for the VEX Hinge yet. Can anyone produce one and/or when does VEXLabs plan on releasing a file?
do you have access to autodesk/solidworks/pro engineer? if so, you should try to make it yourself. it looks simple enough. if i get time, ill make one.
I’m using solidworks and if one doesn’t pop up I might try it… The hinge part is what would be hard.
I could do it in Sketchup or maybe AutoCad, but I don’t have any hinges. If I can get the measurements somehow, I could probably do it without the hinge itself.
