Before I have my students start to build Ike with their v2 kits, does anyone have any suggestions or find any issues when using the build plans for the 1st gen kits? TIA
the programming cable is different than gen 1 and you can press joysticks on gen 2 controller
Ike is pretty easy and it doesn’t use the full parts set like some of the other plans. You shouldn’t have a problem. Use metal shafts where Ike bends at the “waist”, the top half (brain, battery, arms) is a little heavy.
Thanks! Looking at the steps, I was concerned that some of the gears might not translate properly
