For those of you that have finished the VEXIQ certification:
- Can you tell me how long it took you to build the test robot
- Can you tell me how long it took you to do the rest of the assignments/class?
I’m working on a session to build the robot, and want to have a good estimate on how long to allocate for the build part. I’m not a good example, since the robot uses the standard gear base and common ports, I’ve built more of them that I can recall.
I want to be able to say, “Ok robot is done, now if you go and spend xx more hours, you can be certified”
Thanks!
