Not sure what to do or where to make a correction. Should he use C++ or Python to download it instead? When looking at the code in either text language, no errors are showing up.
Thanks in advance for your help. BTW…this is for a Swish herobot.
Also, try using a repeat on the code. I see a few lines that are put on more than once. I’m not sure, but this may help a bit. And @SCFarrell there is actually a place where you can switch to C++ or Python on the supported software, VexCode IQ. To do this, you have to go to File, then select new text project.
