VEX IQ Quadruped
I’ve been working on a VEX IQ based quadruped. It can now lift itself up, which is no small feat, considering it weighs about 1500 grams. It has 8 motors, two for each leg.
The code for zeroing out the motors still needs a bit of work because it doesn’t give me consistent enough results. I do love being able to use the setMotorStrength() function to make stall detection (and therefore end position) very easy. I am using ROBOTC 4.06 for VEX IQ.
You can watch a video of it doing its leg thing here: http://www.youtube.com/watch?v=g7uF0Q-Rlt0. The sound volume is quite low, sorry about that.
= Xander
Source code deffo and construction details will most likely be close up photos and that sort of thing. The VEXAssembler application is a bit hard for me to use :slight_smile:
= Xander
You can watch me test the gait in this video: https://www.facebook.com/photo.php?v=10152096099201815
Still some work to do :slight_smile:
= Xander
No, I am not. The gait stuff was taken from the Internets, I modified it and made it work with ROBOTC (for VEX IQ).
= Xander
