VEX IQ radio module question
My teams currently use the 900 mhz radio module that came in the base kit. I see that the new radio modules are 2.4ghz. Is there a difference in connection quality between the two radio modules?
Thank you
Hi tpajns,
There is no functional difference between the 900 MHz and 2.4 GHz Radios, however each type of radio can only communicate with the same type of radio.
The only major difference between the two radios is that the 900 MHz Radio can only be used in North/Central/South America, whereas the 2.4 GHz Radio can be used anywhere in the world.
Regards,
  • Art
Thank you for your response.
