VEX IQ Rubber Band - Size or Dimesions
Hey, I just wanted to know about rubber bands, and if the size (ex. - #64) or dimensions like length or thickness matters the most. I have rubber bands that are 7’’ in length, and 1/8’’ in thickness, but it isn’t labeled as 117B rubber band. I want to use them, but I wanted to make sure they meet VEX’s rules and regulations. I read the rules, and many different sources say different things, so I just want to clarify things
The 7"x1/8" is the dimensions of a 117B, so you should be good to go. If I’m an inspector, I’m not going to break out the micrometer to measure. The color also does not matter. I like the black ones, but you can also use the standard beige ones, and I’ve also found them in “VEX Orange”
You can use it. These dimensions are for a 117B band!
