VEX joystick programming
We are working in class to program for the joystick and, while the joysticks are working, the buttons are not. We are using programs that we have used before and it seems correct. I’ll paste below. We have tried to do the config but do not get flashing light from red to green. Doesn’t seem to do anything. We have updated all firmware. Any other suggestions? This is something we have done before and I just can’t figure out why it isn’t working. Thanks for any help you can give.
#pragma config(Motor, port1, LeftMotor, tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port2, RightMotor, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port3, LiftMotor, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, ClawMotor, tmotorVex393_MC29, openLoop)
task main()
while ( 1==1 )
motor[LeftMotor] = vexRT Ch2 ];
motor[RightMotor] = vexRT Ch3 ];
motor[LiftMotor] = vexRT Ch1 ];
motor[ClawMotor] = vexRT Ch4 ];
if(vexRT[Btn6U] == 1)
motor[ClawMotor] = 127;
else if (vexRT[Btn8D] == 1)
motor[ClawMotor] = -127;
else
	motor[ClawMotor] = 0;
if( vexRT[Btn8R] == 127	)
	motor[LiftMotor] = 127;
else if (vexRT[Btn8L] == 1)
else
	motor[LiftMotor] = 0;
Putting the ifs and elses in the while loop should fix it:
task main(){
    while ( 1==1 ){
        if(vexRT[Btn6U] == 1){
        else if(vexRT[Btn8D] == 1){
        else{
        if(vexRT[Btn8R] == 1){
        else if(vexRT[Btn8L] == 1){
            motor[LiftMotor] = -127;
        else{
