Vex legal lexan
This past Saturday my team and I attended the Warren II qualifier. When we went to inspection, everything checked out. We were about to sign off when a referee came up to do a last minute inspection. He told us that our plastic was illegal to use due to thickness and it not being lexan and that we needed to take it off before we could compete.
What I’d like to know is where can I get vex legal lexan? Where do your teams generally get it from? We’d like the thickest allowed by vex (.065 I believe?) Without it being overly expensive.
On an off note, what are the physical differences between .07 plexiglass and .065 lexan? As in: does it bend more? Does it crack often? Is it easier to use?
Thanks for the help :smiley:
We get ours here: 0.060" (1.5mm) x 12" x 24" Clear LEXAN™ 9034 Polycarbonate Sheet | U.S. Plastic Corp.
It’s the max size and legal thickness allowed in VEX and is relatively cheap.
Since you appear to be in Indiana I would suggest Andymark as the source of the polycarbonate. It is a little larger than you need at 24"x24" but there is always a need for this stuff. Andymark has both .03 and .06 thickness - the larger size coming in a “smoke” color which is kind of nice.
I order today and get it tomorrow to Wisconsin - they have a great shipping department.
http://www.andymark.com/SearchResults.asp?Search=polycarbonate
ebay for the win :slight_smile:
it is very cheap, i got a 12" x 24" and thickness of 0.0295275591 inches for £5ish including next day delivery :slight_smile:
We always buy our polycarb from Amazon for $8 w/Prime shipping (if applicable). I can believe the thickness issue, but lexan is not the only plastic you can use. What plastic were you using?
Our team was seriously considering getting a Delrin sheet, as it’s supposedly more durable than polycarbonate. That being said, our intake last year could hold many, many sacks on a metal-reinforced polycarbonate tray
I’m not sure exactly what kind of plastic it was but he said the material of it was illegal based on the cracked edge where we messed up drilling a screw hole.
We have bought this before: McMaster-Carr
They are great with shipping.
Ebay and Amazon have decent deals to.
Meyer Plastics is our sponsor and they provided us with 20 sheets of 12x24 lexan for the next few years :smiley: You can always give them a call. I’m sure they will give you a good deal :wink:
Section <R7> has all of the “non vex” legal parts listed. These parts include non shattering plastics such as:
polycarbonate
acetal monopolymer (Delrin)
acetal copolymer (Acetron GP)
POM
ABS
PEEK
PET
HDPE
LDPE
NYLON
polypropylene
FEP
These sheets must be cut from a single sheet no larger than 12"x24" that is 0.070" thick.
I got my polycarbonate on amazon btw: 1/16" thick polycarbonate
Hope this helps!
You’ve had lots of good advice here about where to get the Lexan, but not a lot of information about how it is different from Plexiglas.
To begin with Lexan and Plexiglas are trade names. Lexan is actually a polymer known as “Polycarbonate” while Plexiglas is a polymer known as “Acrylic”… or, more specifically, “Poly meth methacrylate”.
As the different chemical names suggest, the long-chain hydrocarbon… the polymer… that makes the plastic is quite a bit different for both materials. Acrylic tends to be harder and more brittle, while polycarbonate is much more ductile… it can absorb impacts without shattering. Acrylic isn’t so good in this regard, which is why it doesn’t fit the definition of “non-shattering plastic” in the VEX rule book.
When you get your hands on some Lexan, try the following tests and you’ll see the difference between them very clearly:
  1. Use a pair of pliers (bigger is better) to grasp the corner of an piece of each plastic. Bend the plastic to a right angle with the pliers. The one that bends is Polycarbonate… the one that snaps is Acrylic. You can also try this using a sheet metal brake (bending tool in the metal shop, if you’re not familiar with it). Polycarbonate can actually be cut and folded… cold… just like sheet metal. Good luck trying that with acrylic!
  2. Take a sharp knife and try to shave a thin slice off the edge of a piece of each plastic. The acrylic will chatter and be hard to cut… the Polycarbonate will slice… not really easily, perhaps… it is tough stuff… but there will be a very noticable difference.
  3. Drill four, 1/8" diameter holes fairly close to each other. If the acrylic doesn’t crack immediately, congratulate yourself on your drilling technique (you’ve probably ground your drill bit down to make it better suited for drilling acrylic) and then try flexing the piece. Cracks will begin to form between the drill holes. The polycarbonate won’t really be any worse for the wear.
So… why is acrylic so popular? It is reasonably hard, it is more impact resistant than glass (and in thick sections can be reasonably impact resistant in general) and has excellent optical properties. It transmits a great percentage of the light that hits it than polycarbonate, making it a better material for applications where people need to see through the sheet… like the protective “glass” in hockey rinks. It is also, last time I looked, less expensive than polycarbonate.
But you probably figured that out already by using google to search “Lexan vs. Plexiglas”, eh? (Shotgun blast testing at the 1:58 mark in this video Polycarbonate vs Acrylic Plastic - YouTube )
Jason
