Vex memory permission error 038015fc
I have been trying to mess with one of my teammates who hates putting Scotty (that is just what our team calls the vex iq Sammy) on our robot so I tried to add him to the brain with .draw functions. it just sends vex memory permission error 038015fc, I don’t know if there is just not enough storage in the brain to use the images or if it has a different problem, here is my code:
#include "vex.h"
#include <iostream>
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// Controller1          controller
// Motor1               motor         1
// Motor2               motor         2
// Motor3               motor         3
// Motor4               motor         4
using namespace vex;
using namespace std;
#define reverse rev;
int fb = Controller1.Axis3.position();
int lr = Controller1.Axis4.position();
int turn = Controller1.Axis1.position();
competition Competition;
void pre_auton(void) {
  vexcodeInit();
  Brain.Screen.clearScreen();
  Brain.Screen.setFillColor(cyan); //Background
  Brain.Screen.drawRectangle(0, 0, 480, 272);
  Brain.Screen.setFillColor(red);
  Brain.Screen.drawRectangle(22, 22, 458, 250);
  Controller1.rumble(rumbleLong);
  wait(2, sec);
  Controller1.Screen.print("SCOTTY CANNOT BE REMOVED");
  Controller1.Screen.newLine();
  Brain.Screen.setPenColor(black);
  Brain.Screen.setPenWidth(4);
  Brain.Screen.setFillColor(blue); //head
  Brain.Screen.drawCircle(240, 68, 30);
  Brain.Screen.setFillColor(ClrDarkGray);//body
  Brain.Screen.drawCircle(240, 68, 10);//neck
  Brain.Screen.drawRectangle(230, 68, 250, 188);//body
  Brain.Screen.drawCircle(240, 188, 10); //hip
  Brain.Screen.drawCircle(240, 109, 10); //arm,shoulder
  Brain.Screen.drawCircle(268, 241, 10); //knee low
  Brain.Screen.drawCircle(189, 219, 10); //knee high
  Brain.Screen.drawCircle(325, 259, 10); //foot low
  Brain.Screen.drawCircle(215, 162, 10); //elbow low
  Brain.Screen.drawCircle(155, 162, 10); //hand low
  Brain.Screen.drawCircle(190, 141, 10); //elbow high
  Brain.Screen.drawCircle(139, 110, 10); //hand high
  Brain.Screen.drawRectangle(235, 179, 194, 228); //thigh high
  Brain.Screen.drawRectangle(231, 193, 277, 237); //thigh low
  Brain.Screen.drawRectangle(179, 217, 184, 280); //shin high
  Brain.Screen.drawRectangle(271, 232, 322, 267); //shin low
  Brain.Screen.drawRectangle(231, 104, 224, 167); //bicep low
  Brain.Screen.drawRectangle(155, 152, 215, 172); //wrist low
  Brain.Screen.drawRectangle(234, 100, 196, 150); //bicep high
  Brain.Screen.drawRectangle(144, 102, 185, 150); //wrist high
  wait(1,sec);
  Controller1.Screen.print("SCOTTY IS NOW IN THE BRAIN SCREEN");
  Controller1.Screen.print("  [info]: TASK COMPLETE ...");
  Controller1.Screen.print("     Begin Match");
void autonomous(void) {
  // Insert autonomous user code here.
void usercontrol(void) {
  while (1) {
  wait(2, sec);
  wait(1,sec);
    if (lr < 0) {
      Motor1 = true;
    if (Controller1.Axis3.position() != 0 or
        Controller1.Axis4.position() != 0) {
      Motor1.spin(fwd, fb + lr, pct);
      Motor2.spin(fwd, fb + lr, pct);
      Motor3.spin(fwd, fb + lr, pct);
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
Doesn’t crash for me, but that code has plenty of other problems.
At what stage does it throw the memory error ?
Is the brain firmware up to data ?
Don’t worry about my driver control, I was just waiting to make that for a time I can test it
it shows on the error on the brain screen instead of printing to it
Are you using VEXcode or (remember obsolete) VEXcode Pro ?
If pro, it it probably these lines.
which make no sense anyway, if the plan was to shortcut using the controller axis, it doesn’t work that way.
also this line
Motor1 = true;
is useless if Motor1 is an instance of a motor.
edit: and the explanation
Pro creates the motors etc. in a file called robot-config.cpp, this code that generates the motors, and controller, will run after the global code in main.cpp, that means that when you tried to do
The Controller1 instance did not exist, hence the crash.
you need to assign controller axis to lr etc. at the top of you while loop in usercontrol.
ok, I trimmed the unnecessary code other than the other variables and it prints now, I got the coordinates wrong so it looks bad but I can fix that, thanks
