Does anyone know the weight of the 3000miliamp hour battery, standoffs, screws and collars?
Check the spec sheets on the vex robotics website.
Those parts are not included
I will weigh the VEX battery when I have time at around Tuesday, but similar batteries with about the same shape and dimensions way about 408 grams (https://www.amazon.com/Venom-3000mAh-6-Cell-Battery-Starter/dp/B00FE10MCQ#productDescription_secondary_view_div_1498274332041). As what I’ve been hearing, a full length standoff is about the same weight as a 35 hole 2 wide c channel aluminum but I may have to check as well. I’ll make sure to add an edit to this post when I weigh them.
EDIT//: Take a look at this thread: https://vexforum.com/t/best-robotics-servo-load-oscillation/17943/1 (Batteries aren’t there so I’ll weigh them Tuesday)
