We recently attached pneumatics to our robot. When we had pressurized the air reservoir, we tested the pneumatic cylinder manually (by pressing the button on the solanoid) and it extended correctly. I then connected it to the brain and tried to test it with code. At first, it didn’t work (and I assumed the 3-wire port was broken, so I switched ports from A to B) but it continued to not extend. Any ideas on what to do? Thanks!
P.S. here is the code I’m using. It’s just a basic program to see if the cylinder will even extend.
/* Module: main.cpp */
/* Author: celesteroselli */
/* Created: Tue Oct 18 2022 */
/* Description: V5 project */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Pneumatics digital_out B
#include "vex.h"
using namespace vex;
int main() {
vexcodeInit();
Pneumatics.set(true);
wait(2, sec);
Pneumatics.set(false);
