Hello, I was trying to use the VEX programming module, but every time I upload a program it gives me an error. Could someone tell me the proper procedure in connecting the programming module to the controller? I am using RobotC
What is the error?
If you mean the programming cable (http://www.vexrobotics.com/276-2186.html), it gets plugged into the joystick while the joystick and cortex are both connected through VEXnet.
@Kevin Boenisch yes I do mean that cable. I tried that, but it gives me this whole list of possible errors
Have you checked through each of those errors? Usually it’s listed there.
Go to the Windows device manager and make sure the cable is being detected properly and the driver loaded.
