char *a = "";
void InitUart()
usartInit(uart1, 115200, SERIAL_8N1);
void GetUartStr()
a = (char *)malloc(sizeof(char) * 120);
if( fcount(uart1) > 30 )
fgets( a, 30, uart1);
printf("Uart \n%s\n\r", a);
I have an Arduino connected to the cortex via Uart @ baud of 115200 and it is sending out a string 5 times a second the cortex is suppose to grab this string and parse it but it crashing every 10 seconds
Can anyone help with this?
Hi @robokiller,
My initial reaction is that every time GetUartStr is called, new memory is allocated for the string. If you call this function enough times (15 times with a minimal amount of other memory to be precise), eventually malloc will return a NULL pointer when there is no more memory available. You then try to write to a NULL pointer (
fgets
), which causes a SEGFAULT and resets the microcontroller. Try something like this:
char* a;
void InitUart() {
a = (char*)malloc(sizeof(char) * 31);
void GetUartStr() {
if(fcount(uart1) > 30) {
fgets(a, 30, uart1);
You were right, Thank you.
Btw should InitUart(); be in initialize() or initializeIO()?
As per the documentation,
So it may be called in initializeIO() or after. Calling it in
initializeIO
or
initialize
is up to you
