Vex Robot Gearing
For a lift when picking up the mobile goals, can I direct the motor to the gear or is that a bad idea?
Considering that the motor spins at 100rpm, and the lift will want to spin a lot slower (usually around 15rpm), I’ll let you finish the equation.
So I have to but more gears attaching to it
Yes, pretty much for any high torque application (lifting arms, clamps, etc) you cannot directly connect a motor to the mechanism. The exception is a drivetrain, where motors can be directly connected to the wheel axles (in many robot designs).
So what do I put in replacment
Take a look at the trainers for good building tips. Build Instructions - Downloads - VEX Robotics
If you built yourself a clawbot trainer, for example, you’ll learn about the gear-reduction used for the arm.
Hey so to gear your lift down you need to take a lower gear ratio, gear ratios are essentially the ratio of teeth of one gear and another. For example: a common gear ratio for lifts is 1 - 7 which uses a 12 tooth gear on the motor transmitting power to an 84 tooth gear. Essentially this should make lift 7x stronger so it can have the power necessary to lift the goal.
