Vex Robot Mobile goal lift
For s slandered mobile goal lift that is used for the moby bot, do i use green or red motors
you can use red to just be quick and it will work, but if you use green it will lift faster but the robot may have trouble lifting. that is a simple fix. just attach rubber bands to the end of the lift and onto a higher point of the robot. our sister team has a crab like bot and did the same thing. it works really well
I would just use red but do not make it direct while adding rubber bands.
Ok, thanks a lot. It really helped
