Vex Speaker and competition
vex speaker and competition…
I’m trying to get our speaker to play when we activate it (button 8 R) … However it stops any use of the controller when we activate the speaker. I’m assuming the autonomous mode will not work either since we can’t drive with the speaker playing at the moment. I’ll attach my code. I’m sure this is a coding issue we are having. Any help?
#pragma config(Motor,  port2,            ,             tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port3,            ,             tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port6,           RightMotor,    tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port7,           LeftMotor,     tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port8,           ClawMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port9,           ArmMotor,      tmotorVex393_MC29, openLoop)
/*        Description: Competition template for VEX EDR                      */
// This code is for the VEX cortex platform
#pragma platform(VEX2)
// Select Download method as "competition"
//Main competition background code...do not modify!
#include "Vex_Competition_Includes.c"
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the cortex has been powered on and    */
/*  not every time that the robot is disabled.                               */
void pre_auton()
	// Set bStopTasksBetweenModes to false if you want to keep user created tasks
	// running between Autonomous and Driver controlled modes. You will need to
	// manage all user created tasks if set to false.
	// Set bDisplayCompetitionStatusOnLcd to false if you don't want the LCD
	// used by the competition include file, for example, you might want
	// to display your team name on the LCD in this function.
	// bDisplayCompetitionStatusOnLcd = false;
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
task autonomous()
	// Insert user code here.
	// Remove this function call once you have "real" code.
	AutonomousCodePlaceholderForTesting();
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
task usercontrol()
	while (true)
		//Right side of the robot is controlled by the right joystick, Y-axis
		motor[RightMotor] = vexRT[Ch2];
		//Left side of the robot is controlled by the left joystick, Y-axis
		motor[LeftMotor] = vexRT[Ch3];
		//grabber Control
		if(vexRT[Btn6D] == 1)
			motor[ClawMotor] = -40;
		else if(vexRT[Btn6U] == 1)
			motor[ClawMotor] = 40;
		else
			motor[ClawMotor] = 0;
		//arm Control
		if(vexRT[Btn5D] == 1)
			motor[ArmMotor] = -40;
		else if(vexRT[Btn5U] == 1)
			motor[ArmMotor] = 40;
		else
			motor[ArmMotor] = 0;
		if(vexRT[btn8R] == 1)
			playSoundFile("1.wav");
			wait(10);
			clearSounds();
I’m no expert, but I think that if you make a task that runs the file, then when the button is pressed you start the task, it should work. Use a static float for your time in the task.
SkinnyPanda seems to be right.
If you don’t want to debounce, you clearSounds() first then playSoundFile(). If you hold the button it might sound funny, but the wait is unnecessary and is causing your control issues.
