So I have been reading through the forums about the codes used at worlds to make their speakers play music, yet the only code I have found is a nyan cat “wav” file. Does anyone have any ROBOTC programs that play a song through the use of tones or know where they are publicly available?
Hi dsivo, I have been researching this since I have only used “.rso” files in the past. I believe “.rso” files are the only file ROBOTC will play, though I may be wrong. Check out this thread:
Basically you must find a file converter. In the thread it provides two converters:
You should use one of the converters or a different one. Just convert the “.wav” file or a “.mp3” file into a “.rso” file and you should be good to go.
Hopefully this helps,
Haley
