VEX STEPmaker v1.0Beta
VEXSTEPmaker_logo
My name is Hellen Ye and I worked at VEX Academy. I proudly announce the release of VEX STEPmaker v1.0Beta!
The VEX STEPmaker is designed primarily for students and teachers of VEX teams, allowing users to create customized VEX parts by inputting parameters only, which enable the assembly of VEX robots more efficiently and precisely.
Full list of VEX base parts
1x1x35 Angle
2x2x35 Angle
3x3x35 Angle
1x25 Bar
1x2x1x35 Channel
1x3x1x35 Channel
1x5x1x35 Channel
2x2x2x20 Channel
1.625“ Flex Wheel
2” Flex Wheel
3” Flex Wheel
4” Flex Wheel
48T HS Gear
60T HS Gear
72T HS Gear
84T HS Gear
12” Drive Shaft
12” HS Shaft
6” Capped Shaft
5x25 Plate
Rubber Band (228-6633/6634, 275-1089, 276-3990/8076/8077, 228-2500-221/222/223/224, 275-1262)
Chain Link (228-2500-230/231, 276-2166, 276-2214-001/005, 276-2252-002/001, 276-7141-001, 276-2172-001)
Installation
To install the VEX STEPmaker, download the software and ensure that you installed FreeCAD 0.21.2 on your Windows computers.
Set up and run the Software
  • Available on Windows 10 /11
  • Install FreeCAD 0.21.2 first. Ensure that the FreeCAD folder is located under C:\Program Files\FreeCAD 0.21.
  • Download the VEX STEPmaker setup file to your computer.
  • Double-click the .exe file to launch the installer and follow the installation steps.
  • To run the Software, type “VEX STEPmaker” in the Windows App search box, then click the VEX STEPmaker icon.
I don’t know if these parts are spelled wrong in the program but
The word in this case is spelled “Angle” which is mesured in degrees, radians… nnot “Angel” which is a divine being.
Is the source code of this software available somewhere?
Yes, it should be Angle! Thanks for pointing out the typos. The text had been updated.
Thanks for sharing this information!
This seems very practical to me to make the necessary changes to some elements that are part of the structure, it seems that we can achieve something similar to the (Autodesk Fusion 360 Parametric Function).
In STEPmaker we can export the components to which type of extension. I also believe it would be interesting to create a tutorial on how to install this resource.
A hug to everyone!
We are excited to announce the release of the freeware - VEX STEPmaker 1.0.1!
