My Class has nearly finished building the “old” style (green) Clawbots. I learned that whenever our bundle was bought, it came with the swept away balls and competition field. I have found the field but I fear the foam balls are lost and gone forever.
I realize that our stuff is all older, but robotics is robotics and I have to work with what we have. Does anyone have a suggestion for replacing the balls?
If you want the same things you can still buy them here.
If you are fine with hard balls, you could look into the Vex IQ balls from the current challenge which are available here.
Other than that you could probably find something generic or use tennis balls, but they might be heavier and bigger.
