Threads a bit complicated…
Also my answer is based of how std::thread works. VEXcode’s implementation might be slightly different.
vex::thread myThreadName(myFunctionName);
Your first misstake is you put function(5)
, this runs the function and you do not want to do that. Instead just put function
Also you have Controller1.ButtonUp.pressing()
which would run the whole time you hold the button and cause many threads to be created.
Then variables get deallocated when they go out of scope. What this means…
vex::thread t2(function);
The { }
are a scope and when the program reaches the }
all variables declared in this scope are deallocated (t2), unless they are pointers.
The thing with thread
is that when it is deallocated, if it is joinable the program will terminate.
What is joinable…
When you declare a thread it starts running. You can now call .join()
which will wait for the thread to finish, at this point it will be: not joinable
. You can also call .detach()
. This will make the thread run and not be associated with the variable. It will also cause the thread to be: not joinable
. Note that even when the thread finishes running it will still be joinable
Thread Vs Task, what is the difference…
Like the standard std::thread
implementation, threads cannot be stop through the variable. To stop a thread it must end it’s self. For this reason VEXcode has a task class, which does the same thing, but has functions like: .stop()
, .suspend()
, .resume()
to give you that sort of control of stop or pausing the thread. However, vex::task
doesn’t have .join()
or .detach()
So what are the Solutions to implement this the way you want? It depends on how you want it to function.
The simplest is to have a thread the runs another loop, and is started at the beginning of the program. This is just creating a global thread variable, or you can put it in main since the program ends anyway when main ends (As you may remember when main is ready to end, the thread variable will get deallocated, but since it is still joinable it will terminate the program, but it doesn’t matter because main is done anyway).
If you want to have a macro that runs a thread, there are options on how you can do it. First decide: do you want the previous thread to stop when you click the macro again and the previous thread isn’t done yet, or do you want to not allow the macro to work while the thread is running, and do you want to have a button to the thread…
Thread has no way of checking if the task is done, so you would need to communicating between threads. Then vex::thread
has no way of stop a task (unless you communicate between tasks), but vex::task
has very simple function stop or pause the thread.
The simplest way to run a thread from an if statement or somewhere that goes out of scope…
vex::thread(myFunctionName).detach();
You could do stuff like this…
vex::thread *myThreadName;
int main()
//myThreadName is not running
myThreadName = new std::thread(myFunctionName);
//myThreadName is still running
The new std::thread(myFunctionName)
creates a thread, but as a pointer so it never get deallocated. It doesn’t even need to be saved in a variable, but you really should dellocated it when your done, otherwise it will just take up a small piece of memory.
In Conclusion it is complicated, but you really should learn it.
