Hello everyone, I’m a coder for my team and I need our robot to test and such but then I found out that our cable that connects the battery to the brain got damaged and doesn’t work anymore so I bought a 1x4 Molex cable, because I need it urgently and vex takes too long, I just received it and tried it on the robot, and it doesn’t work, anyone knows anything about this? It fits everything.
You should compare that cable to a real V5 battery cable, if the connector on one end is in fact reversed as compared to the VEX cable, it would feed battery voltage into a control data line on the V5 brain, the result may not be good, I’ve never had the need to know what happens.
