I wrote a full-field positioning program and found that when I output the values of x0,y0 on the Controller, both values are normal, but when I output the values of gx,gy on the Controller, the Controller always outputs zero (meaning that the value of gx,gy is also always 0). What’s the problem?
/* Module: main.cpp */
/* Author: Flasd */
/* Created: 1/11/2025, 8:48:53 AM */
/* Description: V5 project */
#include "vex.h"
using namespace vex;
// A global instance of vex::brain used for printing to the V5 brain screen
vex::brain Brain;
motor left1 = motor(PORT14,ratio6_1,true);
motor left2 = motor(PORT15,ratio6_1,true);
motor left3 = motor(PORT11,ratio6_1,true);
motor right1 = motor(PORT10,ratio6_1,false);
motor right2 = motor(PORT17,ratio6_1,false);
motor right3 = motor(PORT16,ratio6_1,false);
motor xiring_ = motor(PORT19,ratio18_1,true);
motor lady_brown = motor(PORT8,ratio18_1,true);
inertial Inertial = inertial(PORT7);
rotation lady_b = rotation(PORT4);
rotation remove_x = rotation(PORT3);
digital_out take_mobile = digital_out(Brain.ThreeWirePort.D);
digital_out up_down_eat = digital_out(Brain.ThreeWirePort.H);
digital_out throww_corner = digital_out(Brain.ThreeWirePort.C);
controller Controller1 = controller(primary);
int autonum = 1;
double gx = 0;
double gy = 0;
double gx_new = 0;
double gy_new = 0;
double ga = 0;
double ga_new = 0;
double ga_now = 0;
void remove_p() {
int leftMotorSpeed =
Controller1.Axis3.position()*1.0 + (Controller1.Axis1.position()*0.35);
int rightMotorSpeed =
Controller1.Axis3.position()*1.0 - (Controller1.Axis1.position()*0.35);
/*int rightMotorSpeed =
Controller1.Axis3.position()*1.0 - (Controller1.Axis1.position()*0.3);*/
if(Controller1.Axis3.position() != 0 && Controller1.Axis1.position() != 0){
leftMotorSpeed = Controller1.Axis3.position()*1.0 + (Controller1.Axis1.position()*0.8);
rightMotorSpeed = Controller1.Axis3.position()*1.0 - (Controller1.Axis1.position()*0.8);
else{
leftMotorSpeed = Controller1.Axis3.position()*1.0 + (Controller1.Axis1.position()*0.35);
rightMotorSpeed = Controller1.Axis3.position()*1.0 - (Controller1.Axis1.position()*0.35);
if (abs(leftMotorSpeed) < 5) {
left1.setVelocity(0, percent);
left2.setVelocity(0, percent);
left3.setVelocity(0, percent);
} else {
left1.setVelocity(leftMotorSpeed, percent);
left2.setVelocity(leftMotorSpeed, percent);
left3.setVelocity(leftMotorSpeed, percent);
if (abs(rightMotorSpeed) < 5) {
right1.setVelocity(0, percent);
right2.setVelocity(0, percent);
right3.setVelocity(0, percent);
} else {
right1.setVelocity(rightMotorSpeed, percent);
right2.setVelocity(rightMotorSpeed, percent);
right3.setVelocity(rightMotorSpeed, percent);
left1.spin(forward);
left2.spin(forward);
left3.spin(forward);
right1.spin(forward);
right2.spin(forward);
right3.spin(forward);
wait(25, msec);
void allreset() {
if (Controller1.ButtonUp.pressing()) {
xiring_.resetPosition();
lady_b.resetPosition();
Inertial.resetRotation();
lady_b.setPosition(0,degrees);
remove_x.resetPosition();
int main() {
Controller1.Screen.clearScreen(); //清屏
//double p = 1.182;
double dtheta;
double dex,dey;
double xc,yc;
double x0,y0;
while(1) {
remove_p();
allreset();
Controller1.Screen.setCursor(1, 1);
Controller1.Screen.print("gyt:%4.2f PROG : %d ",Inertial.rotation(), autonum);
Controller1.Screen.newLine();
Controller1.Screen.print("len:%8.2f ", fabs(fabs(left1.position(degrees)) +
fabs(left2.position(degrees)) +
fabs(right1.position(degrees)) +
fabs(right2.position(degrees))) / 4);
Controller1.Screen.print("take:%d ", !take_mobile.operator bool());
Controller1.Screen.print("axis:%8.2f %8.2f", gx,gy);
left3.resetPosition();
right3.resetPosition();
wait(30,msec);
ga_now = Inertial.rotation();
dtheta = ga_now - ga;
dey = left3.position(degrees) * 260;
dex = remove_x.position(degrees) * 220;
xc = dey/dtheta;
yc = -dex/dtheta;
x0 = xc - xc*cos(dtheta) - yc*sin(dtheta);
y0 = yc - yc*cos(dtheta) + xc*sin(dtheta);
gx_new = gx + x0*cos(ga) + y0*sin(ga);
gy_new = gy + y0*cos(ga) - x0*sin(ga);
ga_new = ga_now;
gx = gx_new;
gy = gy_new;
ga = ga_new;
// Allow other tasks to run
