Karthik,
Thanks for the reply. And yes, I see in Tournament Manager where web publishing can be checked. However, when I tap on “update events” in the Vex Via app, and compare the list of available events to the list of VexIQ events on robotevents.com, there are NONE in common, this tells me that there isn’t a single VexIQ Challenge event on Vex Via. I can’t believe that none of those VexIQ event partners chose to check those “web publishing” boxes when setting there event up Tournament Manager. Also, when I did a trial run of my upcoming tournament, I did check those boxes, and nothing showed up on the Vex Via app.
Thanks for looking into this for me.
Paul
IQ events and results are definitely showing up in via. There was an inquiry about a specific event just last weekend and I verified that it was present in the app. My guess is that IQ EPs did not set up Tournament Manager to publish results for the weekends you looked. The list of events is purposefully limited to those that are in the near future or were in the recent past in order to keep the event list a reasonable length.
We just updated the via server to show all upcoming and recent events regardless of whether the event is publishing results. So now you’ll see a list of all events in via even if the EP is not publishing results.
FYI, you shouldn’t be publishing event results to an official event beforehand just to test it.
