I’m sure this question has been asked before, but I can’t seem to find an answer. Is it possible to use the Vexcode API with PROS? I know I can’t build Vexcode projects with PROS, because they aren’t PROS projects, but is it possible to just exchange the API PROS uses in the PROS project with the vexcode one?
The answer is also no.
But if you’re using PROS, why would you want to use the VEXCode API?
not without a lot of work on your part. you could reimplement the vexcode API in PROS but it wouldn’t be a trivial task, and to my knowledge no one else has done it already
