VEXcode API Reference
I was wondering if there was a official or unofficial API reference website or something i could use i know vex coding studio has one but i don’t know if there is one for VEXcode.
I believe that VCS uses the EXACT same commands as VEXCode, so you should just be able to use that API. Even if VEX made a separate one, it would be 100% identical.
Except there is a lot of room for improvement, such as making it work for Firefox, have better documentation, and better layout =)
you can literally ctrl+c and ctrl+v code from VCS to VEXcode. The language is the same, just research how to do motor sensor setup.
You can also import VCS projects into VEXcode.
Ive had issues importing code from VCS to VEXcode, but if it works i guess.
