Vexcode Error Help
When trying to download my programming to my robot, I receive this message:
[error]: make process closed with exit code : 2
What does this mean and how can I fix this?
That error code means ‘your code has errors.’
we need to see the whole code or at the very least the rest of the log to identify the error.
be sure to wrap your code in [code] and [/code] so it’s readable for anyone who isn’t a sociopath
#include "vex.h"
using namespace vex;
competition Competition;
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
void pre_auton(void) {
  vexcodeInit();
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous(void) {
  // Insert autonomous user code here.
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  while (1) {
    // This is the main execution loop for the user control program.
    // Each time through the loop your program should update motor + servo
    // values based on feedback from the joysticks.
    // while (1){
          Drivetrain.drive(forward);
          if(Controller1.ButtonL1.pressing()){
            Arm.spin(forward);
          if(Controller1.ButtonL2.pressing()){
            Arm.spin(reverse);
          if(Controller1.ButtonX.pressing()){
            Claw.spin(forward);
          if(Controller1.ButtonY.pressing()){
            Claw.spin(reverse);
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main();
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
There shouldn’t be any semicolons by themselves. Remove all your extra semicolons
            Claw.spin(reverse);
Should become
            Claw.spin(reverse);
I am very bad at coding can you explain what I destroyed because im dumb thxAnnotation 2019-12-13 191731
ps my competion is tomorrow so plz help soon thx
Make sure #include “vex.h” is the first line in main.cpp
help plz
sorry wrong screenshotAnnotation 2019-12-13 193734
Does it build? If not, zip up the project folder and send it to me.
Annotation 2019-12-13 195352
how do I declare it ? what is it for anyway ?
thx for the help BTW
hehe
all I did was take it out and no more errors
