Vexcode log files
Hello
Is there a way to log in vexcode.
Like creating a log file where the sensor values are written and can be looked at after the code has run
Thanks
Ashish
You could try printing the sensor values to a txt file on a SD card
Thanks
I tried looking for the block to write to SD card but I can’t find any block that write to an SD card. I am using vexcode for vex IQ
Thanks
Ashish
@turbodog did something like you are looking for. See this article ( VEXIQ Autonomous Programming Tool – Delmarva Robotics) for a description and a link to a video describing what to do. Let us know how it worked out.
Thanks we did look at the link you provided. That link has some great info. Thanks for that.
What i am trying to do is some thing like this
// original code
when controller-button-E up-pressed broadcast forward1
// end original code
we want to log the action into a file so at a later time the students can see the log file
when controller-button-E up-pressed **log("button E up was pressed")** broadcast forward1
This way the students can look at the log file and see what the robot did. we can also log sensor values to see that the robot is picking up the correct values
Thanks
Ashish
There isn’t any SD card capability on the VEXIQ brain. If you are using Robot C, you can use the data log feature that captures the data on your PC. Robot C is free and I highly recommend it.
