When I run my code using the new VEXcode version, an error shows up on the brain saying there is a memory permission error 03802B88. When I run the same code using the older version of VEXcode, the same exact code runs perfectly fine, without any errors. Does anyone have an idea as to what the problem may be?
zip the project up and send me the code
For other having this issue after updating to 1.0.2.
delete the “build” folder inside the project folder, this will cause VEXcode to re-compile all files. I’ll explain more in a separate post.
