Having trouble with our VEXcode V5 text program. we will run the program and it will work. As soon as a change, deletion, copy/paste happens, the program will partially run or not at all. We are using the clawbot, so nothing fancy to work with. Using a drivetrain, remote, and 2 motors (lift and claw). I have also noticed a couple other posts referring to the same or similar problems. Any help would be appriciated.
would you mind posting your code?
