Not sure if this is just me or not, but when I open projects using VEXcode V5 Text, it does not resize the project hierarchy and seems to be set to a fixed size. This issue started right after I updated from 19.07.1619. What I have also noticed is that it seems to be using the Makefile icon for the other files at random.
Here are my computer specifications:
iMac (27-inch Late 2013) with macOS Mojave 10.14.4
Processor: 3.4GHz Intel Core i5
Memory: 16GB 1600 MHz DDR3
I don’t think that has anything to do with your computer. But rather that it simply doesn’t automatically resize, or maybe cause the resolution of your computer is not properly set?
I don’t believe it is an issue with the resolution, as it worked perfectly with the older version of VEXcode and no display settings have been changed. This issue started right after updating to v0.9.
