and to clarify, drawImageFromFile is always available, it just does not show in the simplified auto-complete, but the program will still build.
Hello, I was just wondering if there was a way to change the refresh rate of user control. Thanks
If I’m still using the beta 0.9 version, should I upgrade or would 0.9 still be perfectly fine? Just asking as readjusting the code seems like a pain for the amount of code we have.
0.9 is perfectly fine. Same compiler and build system, it has an older SDK but very few changes there in 1.0. If you do upgrade, then choose “don’t upgrade project” and the project should build without any changes needed.
I was wondering the same thing
I think you’ve already made a topic about this haven’t you? This is not the place to ask for coding support.
how do you enable the expert robot configuration? I cant find a way to switch it on
at the top, click on the project name. Press the bottom buttons in the resulting popup.
Is it planned for terminal input to eventually be enabled? Obviously not the top priority but I am just wondering.
It should already be enabled
Hi,
We went to a scrimmage yesterday and our brain was frizing. Another middle school team coach told us that we have to upgrade to the latest version of the program to fix that. Is it true or we have to replace the brain?
Thank you
Even if it’s not true, both VEXos and VEXCode should be updated to the latest version. There isn’t really a good reason to be that far behind.
