Hi. I am wondering if a code from vexcode v5 pro will work exactly the same on vexcode v5. I have a school chromebook, so I can not use vexcode v5 pro, even though it is what I have used until now.
I think the actual API is the same, but the features of the IDE aren’t. For instance, you can’t have multiple files in your program, and it doesn’t have advanced autocomplete. So yes, the code will work the same, you just need to manually put it all in one file, because there is no way to automatically switch your code over.
I tested both and found out that vexcode v5 actually has better intellisense/intellicode.
