VEXRT Help [R]
Hello. Recently, I have been trying to use a VEXRT controller at school to be able to control our robot, but we have been experiencing some problems. After watching a couple videos, I have came up with this code:
task main()
while(1==1)
	motor[rightMotor] = vexRT[Ch3];
		motor[leftMotor] = vexRT[Ch2];
		if(vexRT[Btn6U] == 1)
			motor(rightMotor) = 127;
		else if (vexRT[Btn6D] == 1)
			motor(rightMotor) = -127;
		else
			motor(rightMotor) = 0;
. After downloading this code onto my robot, plugging in the USB receiver to the robot, then using the controller, it has not worked. Can somebody please supply me with a code which will work by using the two joysticks (pushing them forwards).
Thanks!
I see that you already had some help from the community. Simple tank control of a robot with one motor on each side would be as follows.
#pragma config(Motor,  port1,           leftMotor,     tmotorVex393_HBridge, openLoop)
#pragma config(Motor,  port10,          rightMotor,    tmotorVex393_HBridge, openLoop, reversed)
task main()
    while(1) {
        // Tank drive
        motor leftMotor ]  = vexRT Ch3 ];
        motor rightMotor ] = vexRT Ch2 ];
        wait1Msec(10);
Make sure you are downloading for “VEXnet or USB” or “Competition” and not “USB Only” as that option will disable the joystick.
