#region VEXcode Generated Robot Configuration
from vex import *
import urandom
# Brain should be defined by default
brain=Brain()
# Robot configuration code
controller_1 = Controller(PRIMARY)
digital_out_a = DigitalOut(brain.three_wire_port.a)
# wait for rotation sensor to fully initialize
wait(30, MSEC)
# Make random actually random
def initializeRandomSeed():
wait(100, MSEC)
random = brain.battery.voltage(MV) + brain.battery.current(CurrentUnits.AMP) * 100 + brain.timer.system_high_res()
urandom.seed(int(random))
# Set random seed
def play_vexcode_sound(sound_name):
# Helper to make playing sounds from the V5 in VEXcode easier and
# keeps the code cleaner by making it clear what is happening.
print("VEXPlaySound:" + sound_name)
wait(5, MSEC)
# add a small delay to make sure we don't print in the middle of the REPL header
wait(200, MSEC)
# clear the console to make sure we don't have the REPL in the console
print("\033[2J")
#endregion VEXcode Generated Robot Configuration
from vex import *
brain = Brain()
digital_out_b = DigitalOut(brain.three_wire_port.b)
left_motor_1 = Motor(Ports.PORT1, GearSetting.RATIO_18_1, False)
left_motor_2 = Motor(Ports.PORT2, GearSetting.RATIO_18_1, False)
left_motor_3 = Motor(Ports.PORT3, GearSetting.RATIO_18_1, False)
left_motors = MotorGroup(left_motor_1, left_motor_2, left_motor_3)
right_motor_1 = Motor(Ports.PORT4, GearSetting.RATIO_18_1, True)
right_motor_2 = Motor(Ports.PORT5, GearSetting.RATIO_18_1, True)
right_motor_3 = Motor(Ports.PORT6, GearSetting.RATIO_18_1, True)
right_motors = MotorGroup(right_motor_1, right_motor_2, right_motor_3)
conveyor_motor_1 = Motor(Ports.PORT7, GearSetting.RATIO_18_1,True)
conveyor_motor_1.set_velocity(100,PERCENT)
drivetrain = DriveTrain(left_motors, right_motors, 319.19, 295, 40, MM, 1)
drivetrain.set_drive_velocity(100, PERCENT)
fps = 10 # Change this value to adjust the frame rate
delay_time = 1000 // fps # Calculate delay in milliseconds
while True:
for frame_number in range(8, 4945): # 4945 is exclusive, so it stops at 4944
# Format the frame filename as 'frame_0008.png', 'frame_0009.png', etc.
frame_filename = f"frame_{frame_number:04d}.png"
# Draw the image from file
brain.screen.draw_image_from_file(frame_filename, 0, 0)
# Check for controller inputs
if controller_1.buttonL1.pressing():
digital_out_a.set(True)
digital_out_b.set(True)
elif controller_1.buttonR1.pressing():
digital_out_a.set(False)
digital_out_b.set(False)
if controller_1.buttonB.pressing():
conveyor_motor_1.spin(REVERSE)
else:
conveyor_motor_1.stop()
left_velocity = controller_1.axis3.position() + controller_1.axis1.position()
right_velocity = controller_1.axis3.position() - controller_1.axis1.position()
drivetrain.set_drive_velocity(left_velocity, PERCENT)
drivetrain.set_drive_velocity(right_velocity, PERCENT)
drivetrain.drive(FORWARD)
# Add a delay to control frame rate
wait(delay_time, MSEC) # Ensure that delay_time is correctly defined earlier in your code
Idk what is wrong but it gives me a invalid syntax error at line 67 please let me know what is wrong.
