On December 3rd, 2024, Version 2.2 of the VIQRC Rapid Relay Game Manual was released, and the following changes were made:
Updated Figure FO-1 to show the recommended audience viewing angle and recommended field display monitor location
Updated the definition of Preload to clarify intent
A Ball that is placed in contact with a Robot prior to a Match. See SG1.
- Added S3 as a new rule, stating that each Student must have a completed participant release form on file
Each Student Team member must have a completed participant release form on file for the event and season. A Student Team member cannot participate in an event without a completed release form on file.
- Updated SC5 to clarify intent
An Alliance receives credit for a Pass once both Robots independently contact a Ball before it is Scored or leaves the Field.
- Updated G6 to clarify that parts may not be added to a Robot mid-Match
Note: Swapping one set of parts for another, or adding new pieces to a Robot mid-Match during a G10 or RSC8 interaction is considered a Violation of the intent and spirit of this rule. Repairing a Robot, or reattaching parts of the Robot that fall off during a Match, is allowed.
- Updated SG3 and removed SG3d to clarify intent
When this happens, the Ball must be retrieved by a Drive Team Member or referee, given to a Loader, and re-Loaded.
- Revised SG4f to state that illegally Loaded Balls must be retrieved by a referee or Drive Team Member
If a Ball is introduced improperly outside of the Loading Station (e.g., into the middle of the Field prior to the Rapid Load Period), the Ball must be retrieved by a Drive Team Member or referee and provided to a Loader.
- Updated SG5d to clarify that Rapid Load Balls may only be removed by a Robot action from the Starting Zone in which they were introduced
Rapid Load Balls may only be removed from that Starting Zone by a Robot action (e.g., picked up by an intake, pushed by a moving Robot, etc.). Rapid Load Balls cannot be bounced or rolled out of that Starting Zone by a Loader.
- Added SG5g to clarify intent
If a Ball is Rapid Loaded improperly, the Ball must be retrieved by a Drive Team Member or referee, given to a Loader, and re-Loaded legally before it may be retrieved by a Robot.
- Updated SG6 to clarify that Referees must remove Scored Balls that are stuck inside the Goal Wall
If a Scored Ball gets stuck inside the Goal Wall structure after passing through a Target and does not make it to the Pickup Zone, a referee must free that Ball by carefully reaching into the Goal Wall as quickly as it is possible to safely do so.
- Updated SG6b to state that Balls Scored through Targets must be legally re-Loaded before they are eligible to receive credit for another Score or Pass
A Ball which has been Scored through a Target may not be used for additional scoring, Passing, or Switch Clearing until it is retrieved by a Loader and legally re-Loaded.
- Revised R6a to clarify intent, and add links to the Legal / Illegal Parts Appendices
a. Official VEX IQ products are ONLY available from VEX Robotics. To determine whether or not a product is “official” and legal for competition use, consult the following sources:
i. VEX IQ Robotics Competition Legal Parts Appendix
ii. VEX IQ Robotics Competition Illegal Parts Appendix
iii. www.vexiq.com
- Updated R8 to include Head Referees
Inspectors and Head Referees will have final say in what is considered “non-functional.” Unless otherwise specified below, non-functional decorations are governed by all standard Robot rules.
- Updated R11c to state that attachments to the VEX IQ controller are legal
Attachments which assist Drivers in holding or manipulating buttons/ joysticks on the VEX IQ Controller are permitted, provided that they do not involve direct physical or electrical modification of the Controller itself.
Added T2d to clarify that Head Referees may not be an Event Partner or Judge Advisor for the event
Added T6b to state that Robots may not be placed onto the Field mid-Match
If a Robot is not placed on the Field prior to the start of a Match, it cannot be placed on the Field during that Match.
- Added a tolerance for Ball diameter to T10, and clarified expectations for Event staff
The Rapid Relay Balls are manufactured with a +2/-13mm tolerance for the diameter of a perfectly round ball. Because they are soft and plush, actual dimensions may vary, and it is impossible to guarantee exact specifications/dimensions/tolerances in any given Match. Teams should be prepared for variance in Ball shape/size, and it is expected that Balls will change shape during the course of a Match and/or event. Event staff may periodically or at a Team’s request attempt to re-shape the Balls, but are not required to do so.
- Updated RSC8aii to clarify intent
All Balls must be removed from the Robot and from the Field, and can be returned through the Loading Station or Rapid Loaded.
Added new Significant Q&A boxes throughout the manual
Minor formatting fixes
The next manual update, Version 3.0 will occur on January 28th, 2025.
