Virtual skills vexcode won't open
Whenever I try to open the web based vexcode to access virtual skills I get this error message “The project you are trying to open was saved with a newer version of the application. Please update your application to open this file.” When it opens there is no virtual skills icon in the tool bar.
It sounds like you somehow have an incorrect project loaded in the cache. We store your project on close/refresh of the page to try to prevent users from losing their projects.
You should be able to simply create a new project from the File menu to create a new valid project.
If that does not work, then we will need to investigate this further.
It worked thank you! Is there an alternate way to save programming?
You can save the project more permenantly by going to File → Save To Your Device. That will download the project to whatever device you are using.
