Does anyone have code they have used to control a robot on Virtual Worlds via a Logitech Controller? If so, could you inform me on how you can make such a program?
So the majority of the coding is identical with a few slight changes. You can find a few example programs if you go File → Open Sample Programs → Virtual Worlds → VEX2 → Remote control. Here is one copied for your convenience. The important thing to note is the include joystick drivers and the getJoystickSettings. You must at the top of your program include the drivers and call getJoystickSettings inside of your while loop. Then you call the joystick values using oystick.joy1_y2 and so on.
#pragma config(StandardModel, "RVW SQUAREBOT")
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
/*+++++++++++++++++++++++++++++++++++++++++++++| Notes |++++++++++++++++++++++++++++++++++++++++++++++
2 Joystick Drive
- This program allows you to remotely control your robot using the USB Logitech Dual
Action Joysticks.
- For USB values to be transmitted to the robot, you must follow several steps:
- Use the "#include "JoystickDriver.c"" line at the beginning of your program
- Call the "getJoystickSettings(joystick);" in a loop to repeatedly retrieve the latest values
- Open the Robot > Debugger Windows > "Joystick Control - Basic" window after downloading your
program to the virtual robot
Robot Model(s): Squarebot
* [Name] [Type] [Description]
Motor Port 2 rightMotor VEX Motor Right side motor
Motor Port 3 leftMotor VEX Motor Left side motor
*To run this sample program on Swervebot, be sure to Reverse Motor Port 3 in the Motors and Sensors
Setup, and to make sure that Motor Port 2 is NOT Reversed.
#pragma debuggerWindows("joystickSimple");
task main()
//Loop Forever
while(1 == 1)
//Get the Latest joystick values
//Set the driving motors equal to the Y-axis values of the joysticks
motor[leftMotor] = joystick.joy1_y1;
motor[rightMotor] = joystick.joy1_y2;
Sorry to ask such a novice question, but how would you access the different buttons?
