My teams are starting to do the online virtual worlds challenge. I know the scoring is not active, but what is the deal with the templates? They have tried to use a comp template, a skills template, and just a plain blank non-template file. The only one that works is a blank file… no template. Is this normal? Is this what is needed for the challenge.
Yes this is normal, there is no template for virtual worlds. You can easily check this by opening the sample programs (you don’t need to use them) and seeing that the provided example code doesn’t follow a template.
Hope this helps!
-Justin
